Pajero 2007 MMCS J-02 English Conversion?
Old 09-20-2014, 10:28 AM
ZedX's Avatar
Default Pajero 2007 MMCS J-02 English Conversion?
Hey guys!
I currently have a 2007 Mitsubishi Pajero Exceed, which has an MMCS that is in Japanese. The only difference, however, is that this is a J-02 as opposed to being a J-01 like most other people have requested help with in this thread. The car is in New Zealand and if New Zealand maps are also obtainable that would be great, otherwise all I want is the operating system to be in English (An Australian or American firmware would probably also do the trick too, if a New Zealand one is unavailable).
Looking forward to hearing back from everyone, thanks!
Old 09-20-2014, 03:28 PM
Benckj's Avatar
You know I have been following updates to this and thought I had the JS-01 but after reading your thread I re-checked mine. Appears mine is also a JS-02 version. Believe only diff is the unlock code on HDD and 'Loading.kwi' file is same.
Jim
Old 09-20-2014, 05:41 PM
Benckj's Avatar
To find version number of MMCS hold SET + NAVI for 5 secs to get into service mode. Once there go to the 2nd tab down on right hand column to get version details. Mine was
BLD-NR-261 JM7 1.08
This will revel a key to unlock the HDD. In an earlier thread a list of version keys are listed. After this I believe you follow same directions as given with the JS-01.
Jim
Old 09-20-2014, 06:23 PM
ZedX's Avatar
BLD-NR-261 JM7 1.08
Jim
Awesome, I'll try this out and get back to you!
Oh but by the way, won't I need a different firmware for the JS-02 because its newer?
Old 09-20-2014, 08:18 PM
Benckj's Avatar
Don't think you will but I've yet to get my PC booting with Linex CD.
Jim
Old 09-21-2014, 12:34 AM
ZedX's Avatar
Jim
Turns out I have the exact same version as you! Any clue what the code is? Looking at other threads to figure this out.
Old 09-21-2014, 03:49 AM
Benckj's Avatar
Yes I have code but will need to find link as I have hard copy. Let me do some digging and will let you know how I get on. Would like to get my own sorted soon.
Jim
Old 09-21-2014, 04:06 PM
Benckj's Avatar
this is the thread I used along with a link inside which pointed to the version and known passwords to unlock HDD. Seems the link may be dead but I havn't gone through all 51 pages to source. I do have a hardcopy of table which I can share but unsure if we are using passwrod for a USER or MASTER.
https://mitsubishiforum.com/forum/mi...ck-mmcs-25583/
MASTER pass for NR261JM is
B2BAB3BCBODFACBEB1BBBEDFB1ADD2CDC9CEB5B2DFB19E8996 DFB29E8C8B9A8D
Hope I got that right!
Jim
Old 09-21-2014, 11:52 PM
ZedX's Avatar
Jim
Welp, I took it apart and got it all ready, and I was faced with a rather unfortunate problem. The hard drive (which many said would fit right into a laptop) was, in fact, IDE rather than SATA. That basically means the drive is older, and the connection does not match. Let this serve as a warning to any future people that wish to manually convert their MMCS. Make sure your connection is right, or use an adapter!
Photos:
Firstly, the HDD connection on my (as well as most other modern laptops I'm pretty sure) laptop.
Next up, the hard drive from my PC which fits into this laptop.
Lastly, the IDE (aka PATA) MMCS hard drive, which, as shown here, does not fit into the above plug.
I may of hit a dead end, and even if I got an IDE adapter I do not know how I would fit it into the laptop. On top of that any old laptops which may have an IDE connection are broken, so I think I'm out of luck unless anyone has any other ideas :/
Old 09-22-2014, 05:15 AM
Benckj's Avatar
I've got an adaptor set which goes from IDE/SADA to USB but have not tried with my laptop. If it looks like it would work for you could post off for you to try.
Jim
Quick Reply: Pajero 2007 MMCS J-02 English Conversion?
