02 Eclipse Spyder GT wont start - too much fuel, please help!
I have a 2002 Eclipse Spyder 6cyl that wont start, and Im having absolutely no luck getting it going again. The situation right now is that if I disconnect the fuel pump, crank the car until it kicks over, and quickly reconnect the fuel pump it will start and idle. However as soon as I give it gas it just dies. If I try to crank it again it wont start, and when pulling a plug its obvious that the engine is getting way too much fuel. The only code that the car has thrown was for the EGR system. The below list is what I have tested so far, all without any positive results
-Replaced MAF
-Replaced FPR
-Replaced fast idle stepper motor
-Verified EGR valve is functional
-Tested EGR solenoid - stuck open so I plugged it for now and ordered a replacement
-Verified spark (at least on the front 3 cylinders)
-Verified TPS is working properly
-Ran half a bottle of Seafoam through the engine
-Checked for other vacuum leaks
I think that its unlikely all 6 injectors died at the same time so at this point Im really at a loss as to what to do next.
-Replaced MAF
-Replaced FPR
