4G32 + Aisan carb - Mitsubishi Forum - Mitsubishi Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 10-28-2016, 05:14 AM
Default 4G32 + Aisan carb
Hello. A friend of mine had a 4G32 (early 80's) with an Aisan carb fitted to his forklift a few years ago. Apparently it has never run well. It will rev if you build the revs up SLOWLY, but if you 'blip' the throttle it dies.
I have a kit for the carb coming - what I am wanting advice on is the vacuum lines. Most of the lines on the carb, and also the pipe on the inlet manifold have been closed off - it does not have a brake booster, nor the hot / cold flap on the air filter.
Should any of the carb lines be fitted to manifold vacuum / does it have a power valve that needs vacuum to operate. Anything I need to know about these carbs?
In the photos I have attached (I think) the plunger has been disconnected as I had just taken the top off to make sure I was ordering the right kit, also auto choke is missing - it does run better when warm but a long way off being right
Thread Thread Starter Forum Replies Last Post
engine swap 4g32 crazylegs Everything else 5 10-02-2013 08:51 AM
4G32 Crankshaft same as 4G37? PharmD 2nd Generation 0 11-09-2011 12:02 PM
F/S - 1.6L Mitsubishi 4G32 ZVNJ For Sale / Trade 0 06-22-2010 10:35 AM
WHY IS THERE NO CARB STICKER for a CARB LEGAL INTAKE? seanxmadriaga Intake, Headers and Exhaust 4 08-13-2007 08:43 PM
Fitting power steering to a 4G32 L300 mxer1 Everything else 0 02-03-2007 05:41 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
