fuel rail
Old 11-16-2004, 02:03 AM
BurntGSX's Avatar
Default fuel rail
whats the best? AEM, VENOM, Aero?
cause I've heard Aeromotive makes the best rails.. but most of the people I know have AEM or Venom... maybe its that they have heard of those brands predominantly?
Old 11-16-2004, 09:13 PM
Default RE: fuel rail
the stock one. is all you will need unless your going to have over 500hp anytime soon
Old 11-16-2004, 09:15 PM
or unless you want the [bling] look
Old 11-17-2004, 01:10 AM
You will need it if you get a larger turbo, because you will have to redo most of your fuel system and I believe you need a new fuel rail but you might not
Old 11-17-2004, 10:45 PM
no you do not need to change your fuel rail because you upgrade your turbo. i have a 16g evoIII and i still have a stock rail. what you have to change is the fuel pump,fuel filter to a higher flow one,injectors and fuel pressure regulator.i put a sx fpr in mine with 6an line and fittings,they make a adapter that mounts to the end of the stock fuel rail to put the earls an, fittings on.
Old 11-22-2004, 07:07 PM
BurntGSX's Avatar
I'll get one for "the look" but about the FPR.. will I need one since I have a S-AFC??
Old 11-23-2004, 12:11 AM
you will need a fpr when you upgrade your fuel pump. it will over run the stock fpr if you dont. so if you only have a safc you will not need one. but if your increasing boost levels very high you will need to do the whole fuel system.
Old 12-19-2004, 01:49 PM
You only need an AFPR if you go bigger than the 190lph. Otherwise you are fine with the stock FPR and a 190lph.
A good upgrade to the 2G rail is the 1G rail. The 2G tappers slightly in the middle, don't ask me why, but it does. Find a 1G rail and buff the **** out of it. Get it powder coated any color you want and you are set. Go exotic on that piece and you will be the envy.
Just a thought.
Old 12-21-2004, 11:16 PM
BurntGSX's Avatar
good point. I'll have to look into that
jlh077464
01-18-2007 11:08 AM
annettezaz
05-09-2006 08:24 PM
brandoN^gsT
02-19-2006 01:07 PM
cagiestbat
01-02-2006 09:47 PM
antomx
09-04-2004 07:19 PM
Quick Reply: fuel rail
