injectors not firing on 2 and 3
Old 08-09-2013, 08:04 PM
hooelou's Avatar
Default injectors not firing on 2 and 3
1991 Mitsubishi Eclipse GS injectors not firing on 2 and 3, first cleaned and tested injectors they were fine so put them back in and the car ran fine for 15-20 mins then on second test drive 2 and 3 stopped firing again. I replaced the ignition coil and again during the first test drive it ran great but half way through second test drive 2 and 3 stopped firing. Since then Ive checked power transistor, checked crankshaft sensor now questioning if it could be ECU? When I pulled out the ECU saw that it had been replaced with a rebuilt ECU in 2006, could this be the issue again or wiring maybe? any other suggestions
Old 08-10-2013, 08:53 PM
go-part's Avatar
Former Sponsor
davidsdlck
12-22-2020 06:51 PM
car&driver
05-09-2010 10:00 PM
macrader1
06-20-2008 11:25 PM
tex1994
03-05-2008 03:22 AM
horine
04-13-2004 02:49 PM
Quick Reply: injectors not firing on 2 and 3
