PO101 code but MAF fine
Old 11-15-2015, 12:25 AM
2001Mits's Avatar
Default PO101 code but MAF fine
Hi,
I've been trying to figure out what is wrong with my '01Eclipse 3.0 for a while now. My mileage went from 30 to 23mpg several months ago (obviously an air/fuel system issue). I get an PO101 code which means the MAF sensor circuit is faulty.. so I clean and test the MAF and then test it and it checks out fine - operates in the proper hz range and it responds as it should to idle changes as far as I can tell.
I don't really want to purchase a new MAF. The last thing I want to do is start replacing parts at random to hopefully fix a problem Is there another component that can throw this code that I should be checking? I may have to take it in to get a full diagnostic at some point but I'm hoping some feedback from the forum i might be able to solve this.
Thanks
Old 11-15-2015, 12:28 AM
2001Mits's Avatar
.... I have erased and reset the ecm and still get the Po101 code coming up every time.
cahoca
06-16-2010 11:41 PM
guzmanwc425
11-03-2008 07:55 PM
RCJr9186
07-13-2007 11:35 AM
kounterfeit402
03-15-2007 01:20 PM
girlgetter
09-01-2004 11:08 AM
Quick Reply: PO101 code but MAF fine
