Knocking noise left front
Old May 4, 2004 | 02:34 PM
nailgrl25's Avatar
Default Knocking noise left front
I have a 1999 Galant and when I turn my wheel to the left it kinda thumps. I thought I needed a wheel hub assembly but the shop just called and said my wheel bearing is fine. Any help?????
Old May 22, 2004 | 05:22 AM
BKLYNLANG's Avatar
Default RE: Knocking noise left front
ITS UR CV JOINT! CONSTANT VELOCITY JOINT.
Old May 25, 2004 | 09:32 AM
tweeter11's Avatar
I think BKLYNLANG is right. I had the same problem with a Prelude. If you continue to drive the car it will start to thump all the time and eventually the vibration will back off your lugs sending your rim flying and you setting on the side of the road. I drove my car for a month with the thumping. Whenever I would break I would fill it through the pedal. I would have it fixed soon. (I tryed to do a quick fix by putting a boot on the car, no good.) Hope this helped.
roundigo
Nov 11, 2016 12:12 PM
dvir
Jul 26, 2012 09:15 AM
vpleonard
Apr 27, 2004 08:47 PM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
