Has any one had any problems about carbonized valves
Old Oct 22, 2006 | 06:07 AM
iwantmooreshawn's Avatar
Default Has any one had any problems about carbonized valves
i was told that could be one reason i have no compression in any of the cylinders (and it won't start or run) just seein if anyone has any problems themselves with this situation
Old Oct 22, 2006 | 10:16 AM
Default RE: Has any one had any problems about carbonized valves
Nah i would say that would be true if it was only one cyl with no comp.
Old Oct 22, 2006 | 04:30 PM
what do you think the problem would be if it does have no compression on any cylinder
Old Oct 23, 2006 | 06:52 AM
It must be something in the head.
Old Oct 24, 2006 | 01:44 PM
sounds to me like either your timing is off, or youve bent the valves. But to get zero on all is pretty unusuall, id also make sure your doing the test correctly
Old Oct 24, 2006 | 03:00 PM
i know how to the test ok im a tech this problem is just dumb *** **** see the timing marks are still aligned maybe it jumped the crank sprocket but i dont know the valves aren't bent either so i dont know
Old Oct 24, 2006 | 04:52 PM
ok i was just making sure. Well i would try a leak down test then and see what happens there
Old Oct 24, 2006 | 04:56 PM
wtf is going on here?
I cant think of anything.......
Old Oct 24, 2006 | 05:29 PM
i know im just as confused to see zero compression on all cylinders is f'd up.
Old Oct 24, 2006 | 11:34 PM
i know now you get my frustration it ran fine one day and 10 yours later the next day it didn't run at all and theres no compression at all its stupid as hell
