DSM MAF pinout
Old Jan 5, 2007 | 05:40 AM
silvercoupe97's Avatar
Default DSM MAF pinout
I found this the other day and meant to add it to our list of DSM things. I don't take credit for it, but give it to "Freshlane" from ProStreet. He did the research, I just found it
1G TURBO MAF
1 - Idle position switch
2 - Air flow sensor (signal)
3 - MPI control relay
4 - 5V power supply
5 - None
6 - Ground
7 - Barometric pressure sensor
8 - Intake air temperature
1G N/T MAF
1 - Air flow sensor (signal)
2 - MPI control relay
3 – 5V power supply
4 – Ground
5 – Barometric pressure
6 - Intake air temperature
2G TURBO MAF
1 – 5V Power supply
2 – Barometric pressure
3 – Air flow sensor
4 – MPI control relay
5 – Ground
6 – Intake air temperature
7 – Volume Air Flow
CONVERSION: <1g nt MAF -to- 1g turbo MAF>
Pin2 1g Turbo MAF => Pin1 1g NT MAF
Pin3 1g Turbo MAF => Pin2 1g NT MAF
Pin4 1g Turbo MAF => Pin3 1g NT MAF
Pin6 1g Turbo MAF => Pin4 1g NT MAF
Pin7 1g Turbo MAF => Pin5 1g NT MAF
Pin8 1g Turbo MAF => Pin6 1g NT MAF
CONVERSION: <1g turbo MAF -to- 2g turbo MAF>
Pin1 1g Turbo MAF => ?
Pin2 1g Turbo MAF => Pin3 2g Turbo MAF
Pin3 1g Turbo MAF => Pin4 2g Turbo MAF
Pin4 1g Turbo MAF => Pin1 2g Turbo MAF
Pin5 1g Turbo MAF => - (doesn’t seem like it will be used)
Pin6 1g Turbo MAF => Pin5 2g Turbo MAF
Pin7 1g Turbo MAF => Pin2 2g Turbo MAF
Pin8 1g Turbo MAF => Pin6 2g Turbo MAF
craka
Mar 21, 2014 11:33 PM
Otaku
Sep 17, 2009 03:53 AM
MRakestraw
Jun 4, 2008 07:02 AM
kounterfeit402
Mar 15, 2007 01:20 PM
n5926g
Dec 31, 2006 11:59 AM
