PLEASE READ BEFORE STARTING THREADS
Old Jul 24, 2004 | 10:22 AM
madmat's Avatar
Default PLEASE READ BEFORE STARTING THREADS
This section is for the general discussion of Mitsubishi Motors including our loves, gripes, and concerns for the company in general. Any other threads will be moved promptly to the proper section and double posts when found will be deleted. Please save yourself and the moderators time by posting properly.
Thank You in advance-
The Moderators
Old Aug 24, 2009 | 11:26 PM
mitsu man 91's Avatar
Default help me!!! (lift kit)
hey guys, im the proud owner of a great 90 montero utility 4*4 and need a 3" suspension lift. ive thought of trying a 90 4runner kit but am kinda shaky bout that. dont need much, just sommor room for my 31" mudders and additional flex. any ideas would be great! HELP ME!!!!
Old Jun 12, 2011 | 09:37 PM
mara133's Avatar
helllo
Old Jul 20, 2011 | 09:27 PM
tmit2007's Avatar
Default How does this work?
Want to post ? re: trans pan bolt on 07 outlander. How do I do it?
Thanks in advance for the info.
Old Oct 16, 2011 | 10:10 PM
Outsporter's Avatar
Default How about a OUTLANDER SPORT section
I just bought a 2011 Outlander Sport SE I'd like to see a seperate section for Outlander Sports on the forum.
Old Dec 21, 2011 | 06:53 AM
andersongreen's Avatar
how should i post about out lander in this site?
Old May 30, 2012 | 06:12 PM
Rleo6965's Avatar
Hello. I own a Mitsubishi Lancer EL 1996. We call it "itlog" here in Philippines because of its EGG shape Tail Light. I don't know the equivalent model here in your forum. It had 4G13A SOHC engine and using Variable Venturi Carburator and Distributor with built-in Ignition coil.
I'm now rebuilding my 4G13 engine. I already have it re-sleeve or Liner and rebore to standard bore of 71mm. My problem now was I want to know how to clean the internal parts and small oil holes passages to remove clogged dirty oil. I don't want my new oil to be contaminated by old and dirty which have abrasive materials.
I want also to clean the Oil Pump without opening it. Can I use kerosene and air pressure to clean it.
Hope you can give advise. Thanks.
Old Oct 4, 2012 | 05:54 PM
putan_131967's Avatar
Hi There, My problem that I'm facing this morning is the 4WD indicator light (green) is blinking. I did not shift the lever. It is on 2H setting since I used it.
On 4WD lever it shows 4L, 4H and 2H. In normal drive or in expressway the settings is 2H. My car is Nativa 2008 model, gray color....thanks!
Old Jan 21, 2015 | 07:30 PM
spench317's Avatar
Default Montero, how to fix heater core??
Alright I've got a 1990 montero, has no heat. I've checked everything and it's got to be the heater core.
How in the world do I get to it? Anybody know? I've checked everywhere online and only seen one picture showing it behind the firewall and dashboard and all. How in the world?
Anybody have any advice?
Thanks!!
Old Jan 24, 2015 | 08:00 AM
2001Mitch3.5XS's Avatar
Have you tried https://www.mitsubishilinks.com for you manual, It may be of help.
You will have to take the dash apart to get to it.
You say you have NO heat, Well the core is just a radiator. Have you checked your fan fuse, Thermostat before digging in to such a big job.
