Maintance ?
Old Apr 18, 2007 | 06:00 PM
RMUDBUGS's Avatar
Default Maintance ?
Has anyone changed there rear end oil? The owners manuel says to do it every 15K but mine has 18K and I have not touched it. The only maintance I have done is a tire rotation and oil change with Mobil 1 every 5K.
Old Apr 18, 2007 | 06:02 PM
Dusty Eclipse's Avatar
Default RE: Maintance ?
Did you take it to Mitsu to get it done? I know on GSXs they did the back end when they did the regular oil changes...
Old Apr 18, 2007 | 06:30 PM
RMUDBUGS's Avatar
I have not had it done yet. I work at a Mitsu dealer so the do all my maintance.
Old Apr 18, 2007 | 07:23 PM
silvercoupe97's Avatar
Yup, the rear diff needs it's oil changed along with the tranny (manual) andtransfer case.
Old Apr 18, 2007 | 07:31 PM
RMUDBUGS's Avatar
Mine is 2WD and the automatic tranny fluid is to be changed every 60K. 15K for the rear end seems a little soon to me.
Old Apr 18, 2007 | 10:44 PM
Dodge has had terrible times in the past of keeping their axles together.
So much so that they created their own 140 weight synthetic axle lube. use NOTHING ELSE in the rear end, and change it at the correct intervals.
Old Apr 19, 2007 | 08:32 PM
RMUDBUGS's Avatar
Mitsu list 2 rear end oils. A 75W-90 and a 75W-140. Both are synthetic. So I called the local Dodge dealer and they told me that they use the 75W-90 and only reccomend the 75W-140 for extreme uses (i.e. towing, mud riding).
Old Apr 25, 2007 | 02:29 PM
RMUDBUGS's Avatar
I just checked the service manuel and it said to use 75w90 for the front diff. (4wd) and 75w140 for the rear diff. Plus the LSD additive.
Old May 16, 2007 | 11:15 AM
RMUDBUGS's Avatar
Well I changed the rear diff fluid yesterday (20K). The fluid was very clean, with no metal. I think I will go a lot longer before changing it the next time. I'm thinking 30K to 50K.
Old Nov 20, 2008 | 10:37 AM
60cdnstd's Avatar
Be sure to double check your owners manual. I just bought an 06 Raider XLS with 18k miles. I was going to do the front and rear differential fluid maintenance just to be safe since the manual said 15k miles and I dont know if it was done.
After a closer look at the manual I noticed that Mitsu put the severe driving maintenance schedule before the normal driving schedule. So unless you are doing alot of heavy towing or off roading you can wait alot longer for the fliud change. I dont have it in front of me but I think it said like 60k miles.
