420A will not start!
Old Aug 20, 2007 | 07:56 PM
95eclipse420a's Avatar
Default 420A will not start!
I just had my 420A rebuilt with everything done to spec. I put it back in the car and now it will not start, After a couple of seconds of cranking it will backfire out of the intake? but thats all it will do.it has fuel/air/ & spark/ plus ive gone over the wiring over & over and everything is right, Theres a couple of things im not sure if there causing the problem or not? 1 the ECM is making a a low buzzing noise, is this normal? or is mine bad? 2 it also looks like the sensor all the way to the left, if your sitting in the car, on the back of the block has a little crack in it, can anyone tell me what this sensor is called so i can replace it? Someone told me the timing could have jumped, does anyone know if theres a way i can go about checking this if the cars not running? anyone that has any info, Thanks
Old Aug 20, 2007 | 08:08 PM
95EclipseGS95's Avatar
Default RE: 420A will not start!
re set the timing that is what i wound try
Check the timing marks... i have a feeling thats where your issue is
Old Aug 20, 2007 | 09:58 PM
antlip's Avatar
Is the sensor that your refering to the knock sensor look something like this?
Old Aug 21, 2007 | 01:12 AM
racerx55's Avatar
i say cams are out of time. there are marks on both sides of the gears, its not hard to put one 180* out
Old Aug 22, 2007 | 07:19 AM
teg96's Avatar
check timing marks, i have a friend that did the same thing, with the rebuild and all. and his timing sliped, and was doing the same stuff your is doing. good luck.
Old Aug 22, 2007 | 11:29 AM
Ok thanks to everyone that replyed! my problem now is that when he put it together, i had him in install crower stage3 cams & unorthodox cam gears,
so with that being said, the plastic piece with the timing marks is gone, so my next question would be how should i go about checking it without those timing marks? someone told me about a something called a dial gauge? does anyone know where i can buy one, and if so will that work?
Thanks Again
Old Aug 22, 2007 | 11:30 AM
I swear that the timing markes are on the gears themselves?
Old Aug 22, 2007 | 11:34 AM
there are but, isint there sopose to be one one the bottom to?
Old Aug 22, 2007 | 11:37 AM
You mean the crank? Yeah.. its on the sprocket.. or it should be.
