Need Help with Mitsibishi LRV
Old Jan 9, 2008 | 11:29 PM
marbledragon's Avatar
Default Need Help with Mitsibishi LRV
Hello,
If you could help me with this problem, I would really appreciate it. Mylittle LRV is running, but every once in awhile the engine stalls and the check engine light comes on. The engine hesitates and stops running for a second, then it continues to run normally.
I have been driving it with the overdrive turned off for some time because it does not run at all at high speeds with the overdrive turned on. I understand that this is a common transmission problem with this model. Perhaps there is a connection between the two problems.
has anyone else had a similar problem? Does anyone have any ideas on what could be wrong?
Thank you. I highly appreciate it.
-Holly
Old Jan 16, 2008 | 06:56 PM
1987 TSI's Avatar
Default RE: Need Help with Mitsibishi LRV
I am not familiar with your car but it sounds to me like the converter is staying locked up sometimes. I had the same thing happen in a topaz once.
db1outs2
Jun 29, 2013 01:21 PM
elherron
Nov 23, 2011 02:27 PM
alan graham
Other Mitsubishi Models
Nov 11, 2009 03:34 AM
Kolhoznik
Feb 18, 2006 09:31 PM
Donna_K
Oct 27, 2005 04:19 PM
