laptop to eclipse?
Old Jan 21, 2008 | 03:05 AM
infinity8x3's Avatar
Default laptop to eclipse?
I herd there is a way to hook a laptop up to a 2g eclipse and with software you can make changes or read codes or something. Any one know if its true? Sorry stupid question i found it it's called DSMlink
Old Jan 21, 2008 | 06:12 AM
Default RE: laptop to eclipse?
well dsmlink is for tuning. On their website they will describe all the functions and what you need to be able to use it. But you only need dsmlink if you planning on running an upgraded turbo and like 350hp+. But if all your looking to do is read codes though the obdII wire then there are a couple ways. One is you can get an actual scanner. Or the cheaper way is to buy a cheap palm pilot and upload the software for the OBD then just buy the cable you would need
Old Jan 21, 2008 | 11:30 AM
nyc95gst's Avatar
Hey where can I get the software for the palm pilot and what cable?
Old Jan 21, 2008 | 12:16 PM
Here is where you get the cable and program
http://www.pocketlogger.com/?pid=plobdii
Then read up here as to what type of pda is good to use with it. But when most OBD readers are more than $200. This way you will spend about $150 however you willhave alot more capability than a OBD reader because the pocket logger can actually extract data from other sensors on the car such as timing and o2. Some people actually use these for tuning
Old Jan 21, 2008 | 12:38 PM
nyc95gst's Avatar
Thx Engineer, I have a old PDA lying around so I will see if it is compatible with the software. Thanks for the link and info.
Old Jan 21, 2008 | 01:00 PM
nyc95gst's Avatar
NM :]
Old Jan 21, 2008 | 02:57 PM
Wi_Fibre's Avatar
I used to have a '96 dodge avenger and If I'm correct I'm pretty sure it will work on the 2g eclipses, with this method it will cost you $0 to retrieve the ecu codes, in as little as 1 minute. I'm pretty sure it will only work for years 95-97, but I've heard it's worked for a few 98's.
You put your key in the ignition and turn it as follows....KEY ON-OFF, ON-OFF, ON_KEEP ON the check engine light should blink the codes, there will be a pause to indicate the next number. Here's an example....(23)......blink..blink......blink..blin k..blink. I'm pretty sure you turn the ignition on/off 3 times, to get the check engine light to flash, if it doesn't work try it turning the ignition on/off 4 times, its been while but I think 3 times is correct.
Then again there's always another quick and simple alternative for all cars made with the OBDII connector (years 96+), go to Auto Zone, Advanced Auto, O'Reilly Auto Parts, or a similar auto parts store they will usually check your ECU codes for free.
Old Jan 21, 2008 | 03:49 PM
yes the key dance does work. I posted a link a while ago in the faq's for it in the DIY section
Old Jan 21, 2008 | 11:00 PM
98gstspy's Avatar
what will this type of thing do exactly? what can it change?
Old Jan 22, 2008 | 06:23 AM
what will what thing? we have talked about a couple things in the thread. The palm pilot thing is ONLY for monitoring. There is no way to change anything with it.
xLoveMeXoTenderX
Aug 25, 2007 11:55 PM
B33Z
Oct 24, 2005 03:00 AM
