diamante keeps dieing
Old Nov 18, 2004 | 10:30 PM
arcticz28's Avatar
Default diamante keeps dieing
Hi, I have a 1992 diamante and it starts dieing as soon as it warms up. I try starting it again and it starts fine but the dies about 5 seconds later. can anyone help?
Old Dec 6, 2004 | 02:29 PM
DiamanteDomz21's Avatar
Default RE: diamante keeps dieing
I hate to be the messenger, of bad news but you are gonna need to check and/or replace the ECM (brainbox)..my 92 does about the same thing...or it is fuel pump/pressure related
Old Feb 25, 2005 | 09:07 PM
Winshawn's Avatar
No, it is probably the throtle body is dirty or the IAC (idle air control motor) has failed. The IAC is what controls your idle speed. If the ECU is bad you will get a check engine light. A bad IAC does not have a code.
Old Apr 18, 2005 | 01:10 AM
wicked_outlander's Avatar
first of all, check your tune up....if the problem persist, you may wanna check fuel systems ( hose's, filter, injectors. rails. pressure and pump) then your ignitions. see if you getting enough sparks from your wires.
KaiserEclipse
May 26, 2011 05:45 PM
racinrookie88
Feb 20, 2009 08:39 PM
JesterGTO
Jun 28, 2006 10:22 PM
ron Kirk
Jul 31, 2005 01:45 PM
arcticz28
Nov 18, 2004 10:43 PM
