Mitsubishi
  #61
Old 04-03-2009, 01:17 AM
lalamax lalamax is offline
i am new to the board
just picked up last week, and installed HID on day one hahaha
I didnt go thru all these trouble, I just got a "Cambus" ballast, DRL problem solved...
  #62
Old 06-02-2009, 12:03 AM
cbcctv cbcctv is offline
Dan I need your help!!!
I was using 25V 3300UF capacitor but instead of soldering it to the switch ,I soldered it to the organge socket below.I tested it and worked good when I put the key on ignition,which DRL normally on. However,when I turn the headlights on ,the capacitor blowed up. my question is Do I need to solder the capacitor to the switch only ???
Mine s 06 outlander and now I have to keep my headlights on all the time otherwise it won't light up.I don't know whats wrong with it.
  #63
Old 06-07-2009, 02:36 AM
Mitsu28 Mitsu28 is offline
Hello, I'm new here and I read almost all the treads about HID conversion... I would like to know if there's any way to 'send'' the 9 Volts(signal for DRL) at the High Beams? Just because I don't want the HID running all the time as soon as I release the hand brake...I' have an Outlander and I'm from Canada! Thanks
  #64
Old 07-13-2009, 04:13 AM
VancouverMitsu VancouverMitsu is offline
Default in line HID capacitors
can you use in line HID capacitors instead of the relay and capacitor?
http://www.automotivelightstore.com/...ROD&ProdID=232
  #65
Old 09-14-2009, 05:46 PM
bimmer4life2009 bimmer4life2009 is offline
Sure, you can use that instead
__________________
HOW TO MAINTAIN A CAR
  #66
Old 09-19-2009, 10:36 PM
Emil Emil is offline
The first post mentions problems with the Canadian DRL's. Will I face the same issues with my "Non-Canadian" Outlander? I am looking to purchase this kit: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT I also want to purchase a kit for the fog lights. Any of you have any idea if the fog light kit will have enough length to reach the battery?
__________________
08 XLS 2wd
  #67
Old 10-14-2009, 09:23 AM
ryandlor's Avatar
ryandlor ryandlor is offline
Sorry to beat a dead horse...
So now My Wife really wants the HID Conversion after I did it on my 2009 Mazda CX-7. It was an easy Job because the CX-7 Has Projector Housings and the DRL has a separate halogen light than the actual low beams.
So 2 Questions for my Canadian HID Outlander COnversion...
Should I opt for Projector housings? (Purchase the complete housing from an US model that came OEM HID)
or
Just go with a Kit and use existing housings with a capacitor... I really can't see it looking proper. Almost all OEM HID's I see come in projector housings....am I wrong?
__________________
2008 OUTLANDER ES AWD
4 BANGER!!
  #68
Old 10-15-2009, 01:08 PM
Eh Emil, the wiring is already installed from the battery to the bumper. You need to remove the bumper though to pluged the wiring. I did it, I have an Outlander LS 2008.
  #69
Old 10-18-2009, 04:26 PM
moab361 moab361 is offline
I've got an extra set of HIDs, with capacitor to solve DRL problem. They're 5000k, from a reputable company.
Tested and working great, say $65 shipped? PM me.
  #70
Old 10-30-2009, 01:48 PM
mikeps3speed mikeps3speed is offline
That's a decent deal, do you still have them?
__________________
Mitsubishi Fog lights
Tags
08, 2004, 2200uf, capacitor, capacitordo, conversion, drl, harness, hid, housings, jdm, lamp, lancer, rear, sportback, wiring, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
