Infinity Adapter
Old Jan 16, 2005 | 03:00 PM
vertstanggt's Avatar
Default Infinity Adapter
I was looking at a cardomain catalogue and they have an adapter so you can hook up an aftermarket deck without having to rewire a bunch of stuff if you have the infinity system. It may even keep the amp hooked up. I know people have been asking about that so I figured I'd let you guys know.
Old Jan 23, 2005 | 01:02 AM
customizedrides's Avatar
Default RE: Infinity Adapter
Yeah if you're looking to replace the factory stereo you can just get a regular Mitsubishi harness and an Amp interface. This will allow you to still use the factory amps for your speakers and it's only $22. This just wires in back of the deck inline with your speakers and allows you to adjust a gain setting to lower the output signal from your deck. If you don't want to use the factory amps then get the amp bypass kit witch may be a little more expensive, and has more work to it.
Old Jan 30, 2007 | 01:47 AM
ecco303tke's Avatar
yeah...go here guys
http://www.cardomain.com/item/PERMITAH
kcnal
Dec 25, 2006 04:54 PM
dlx_11
Jul 15, 2006 02:27 PM
Warren
4th Generation
Apr 3, 2006 09:50 PM
vertstanggt
Dec 25, 2004 02:31 AM
714mitz
Oct 30, 2004 09:33 PM
