Mitsubishi
Old 04-13-2009, 09:49 PM
antmag33 antmag33 is offline
Default 2004 mitsubishi montero limited vibration
Im having a problem with my 2004 Montero Limited 3.8. The vehicle has 34,000 miles on it and whenever it seems you attempt to drive at a steady speed above 50 mph, you feel a weird rumble or vibration throughout the truck. This same sensation occurs whenever you let go of the accelerator and attempt to just coast. Its a strange rumble feel that seems to go away as im accelerating, but returns as soon as i let go off the gas or attempt to coast. The vehicle also seems to take of strangly on turns for the first 20 minutes of driving the car, like a start and stop hesitation feel. I owned a 2002 montero xls that drove a lot smoother without the strange vibration feel. I cat figure the problem out and I am going to get a alignment tomorrow to see if it helps, although it doesnt feel like a front end vibration, and i dont really feel it in the steering wheel, more in the seat of my pants. Just had the tires rebalanced, but didnt seem to change anything. Im hoping that someone possibly has had a similar problem that they solved and can help me with this. Thank You in advance for any help.
Old 04-15-2009, 01:56 AM
humhai420 humhai420 is offline
i have the same problem the revs are about 2000rpm ish
the car sounds like a rumble type noise very faint then goes away if i speed up or slow down
the the mitsu tech said dont worry
so i dont
Old 04-20-2009, 07:49 PM
meak meak is offline
I have 2004 Mitsu Montero Limited with 60k miles. I never have any vibration issues at all. Truck runs smooth above and below 50m/h.
Meak
Old 05-02-2009, 10:08 AM
tj90 tj90 is offline
Id check tire balance, alignment, brokken/loose suspension components and wheel bearings. Look at the rims for missing wheel weights. Then lift wheel, grab tire at top and shake - is the wheel loose?
Old 10-31-2009, 12:01 PM
javoli001 javoli001 is offline
If the vibration goes away when decelerating .. In my opinion it´s a drive line Problem.
Have you had any problems with drive shafts and / or the T case ?
Have you serviced Tranny, T Case , or differentials ?
Tags
1996, 2004, 38, codes, drive, forum, forums, limited, mitsubishi, montero, professional, shaft, sport, steering, vibration
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
