3000gt vr4 doesn't start
Old Aug 6, 2009 | 01:58 PM
civicdestroyer's Avatar
Default 3000gt vr4 doesn't start
replaced head gasket, head has been shaved, redo the vavles, replaced maf sensor, complete tune-up, got another ecu, and new timing belt. The car started but act up wierd so i replaced the ecu and it was running fine. after 3 days i started it up at night and the vr4 just cut off imediately. the car cranks but keeps getting cut off imediately unless i keeep rpessing the gas and even if i press the gas the car's rpm is very low at .05 rpm. also i replaced the ecm. i checked the timing and it was fine. took of a gas line near the injectors and crank the car to see if gas comes in adn it does bring gas. what could be the problem? please help me. the car only has 45,000 mileage.
Old Aug 11, 2009 | 09:07 AM
BEAT's Avatar
3000 GT is complicated especially with a narrow space working around the engine.
did you adjust the valve correctly?
mitsugirlie
Jan 2, 2008 06:01 PM
davedesmo
13
Sep 28, 2007 06:10 PM
1995MONTYSR
Sep 1, 2007 10:54 PM
Marah
15
Feb 28, 2007 07:58 AM
deltadave
Dec 6, 2006 08:09 PM
