30K Service Questions
Old Sep 18, 2009 | 09:19 PM
red123's Avatar
Default 30K Service Questions
I have a xls 07 so in the booklet says inspect and adjust intake valve clearance.
Also check and service exhaust system for connections an so on in the maintaince schedule.
For the spark plug change, do I need to change that only one exposing in the front of the engine only?
Is that all necessary? and do I really need a auto transmission fluid change
________
Venture
Old Sep 19, 2009 | 02:03 PM
red123's Avatar
upped
________
Angelina jolie pictures
Old Sep 19, 2009 | 02:30 PM
ccernst's Avatar
if they called for a spark plug change, then that'd mean all 6 were to be changed. I read the back 6 are ugly to get to.
I'm trying to figure out what to do about my ATF fluid as well. Book says 30k, my dealer said it was good until 45k and hasn't been done yet. i'm a bit upset about that.
Old Sep 19, 2009 | 04:23 PM
red123's Avatar
oh thanks
dam 6 sparkys hard to get to. is it all on the bottom? I see one in front count as one.
________
MEDICAL MARIJUANA DISPENSARY
Old Sep 19, 2009 | 05:16 PM
ccernst's Avatar
should be 3 in front, 3 in back
Old Sep 19, 2009 | 09:01 PM
rip14's Avatar
You should not need to change spark plugs yet. They last a very long time.
The Iridium plugs last over 100K miles.
Check out this thread:
https://mitsubishiforum.com/forum/showthread.php?t=33039
Old Sep 19, 2009 | 10:27 PM
Iridium plugs are a rip off, and Mitsubishi engines don't last long with them.
Stick with good ole $3 NGK Classics. They are the best for our cars.
Also, the transmission flush should be performed at 60k. 30k is with the severe maintenance schedule I believe.
Old Sep 20, 2009 | 11:29 AM
red123's Avatar
ahh theres that thread i was looking for thanks!
Whew i was about going to touch my spark plug but I guess I wouldn't do so for a long time.
________
New jersey dispensaries
Old Sep 20, 2009 | 11:30 AM
red123's Avatar
any1 know about the intake valve clearance or whatever? the outtie has the engine # listed on it.
________
Chevrolet Beretta
Old Sep 20, 2009 | 12:05 PM
It's the distance between the rocker arm and the valve stem. You can do it by taking off the valve cover and checking it with a feeler gauge.
