Old 10-04-2009, 10:00 AM
rsoto rsoto is offline
Default weird sound when braking
My Montero Sport 03 AWD/4WD makes a weird sound like "clack ... clack....clack".
I changes direction and suspention parts, even bearing of the front rigth wheel but didn't stop the sound.
Brake pads are 5,000 mi old and I resurface the disc at the same time.
Could it be a AWD/FWD problem?
Old 10-04-2009, 10:25 AM
dsm1990gsx dsm1990gsx is offline
Is the noise coming from the front of the vehicle or rear?
__________________
2001 Mercury Sable
1990 Tsi Awd 12.8 @109.9 s16g @ 22lbs 2.0 60 ft.
1990 Eclipse Gs
Old 10-05-2009, 10:59 AM
The sound is coming from the right front wheel, I believe it something rotating, check break pads, safety spring, torque the screws of the caliper everything is ok.
It sounds like is breaking apart but other than the sound it self I don't feel anything in the brake pedal (like bend disc), and it only happens when little pressure is apply to the pedal.
The mechanic change ball bearing, bushings, ball joints with no improvement at all .
Old 10-05-2009, 01:08 PM
challenger4x4 challenger4x4 is offline
Are you sure the bearing pre-load was set correctly? Does the sound happen when you are turning the wheel or also when going straight? Does the frequency of the "clack...clack" sound increase or decrease with vehicle speed or is it constant regardless of speed? Is it ONLY occurring under brake application or can you also hear it with no brake pressure applied?
__________________
- 2003 Montero Sport XLS AWD (current)
- 2006 Nissan Altima SE-R (current)
- 1999 4X4 Montero Sport Limited (retired)
- 1997 4x4 Montero Sport XLS (retired)
- 2003 Galant LS (retired)
- Lots of cars and SUVs before that
Old 10-05-2009, 04:41 PM
Try swapping the rf tire w/ the lf and see if it makes a difference. What condition are the rotors in?
__________________
2001 Mercury Sable
1990 Eclipse Gs
Old 10-05-2009, 05:39 PM
The sound occur in any position of the wheel turning or in straight line, and yes the frequency increase with the speed, but only when I step on the brakes.
The rotor looks ok but they have been resurface 2 times. What's the minimum thickness for the front rotor so I can go and check them up.
Old 10-05-2009, 07:44 PM
Sorry, no idea. Do the pads have a wear indicator and is it positioned correctly (facing inward at the bottom of the caliper)? Are the spring clips and pad shims in good shape?
Here's the specs from a U.S. factory shop manual.
BRAKE DISC (ROTOR) THICKNESS
Standard value: 24.0 mm (0.94 inch)
Minimum limit: 22.4 mm (0.88 inch)
Thickness variation (at least 8 positions) should not be more than 0.015 mm (0.0006 inch).
__________________
Old 10-26-2009, 10:48 AM
I looked at my front disc and they have some cracks, but I don´t think this is the cause for the weird sound, I´m almost sure it come from the safe spring.
When I pull or push them they make an identical noise, can this spring worn out?
I´m going to chance the disc for new ones and have a final check on those springs.
Old 11-14-2009, 01:52 PM
It was something related to the disc brakes, I replaced them with new ones, that weird sound is gone. Checking up the right disc rotor found out there is a small crack, so after changing bearings, direction parts and bushing I finally have a quiet car.
thanks everybody
Tags
2000, 2003, 4x4, bearing, eclipse, front, min, minimum, mitsubishi, montero, preload, rotor, rotors, sport, thickness, v6, wheel
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
AutoAnything
- Magnaflow Exhaust
- Lebra Car Bras
- Car Vacuums
- Brake Parts
- Air Filters
- Coverking
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
