oil pressure sensor and throttle problems
Old Oct 12, 2009 | 01:11 PM
zdski's Avatar
Default oil pressure sensor and throttle problems
2001 Spyder GT Convertible V6
It appear the CEL code is telling me P0120(throttle sensor). I replaced the sensor and still show a CEL w/p0120. There is a hesitation in the acceleration when applying a load to the gas peddle. It is as if the car is pulling a trailer and will not allow any speed past 40mph. Could it be an O2 sensor? I also need to replace the oil pressure sensor. Could this be related? Where is the oil pressure sensor located?
Old Oct 12, 2009 | 01:15 PM
If you replaced the tp sensor you probabaly have an issue with the wiring from the tp sensor down to the ecu.
The oil pressure sender is on the oil filter housing.
eclipse1825
Aug 18, 2011 06:53 PM
9LIVEZ
Nov 3, 2008 04:33 PM
foetus envy
May 16, 2008 12:42 PM
newguy2007
Dec 24, 2007 10:13 PM
