I suck at driving
Old Nov 7, 2009 | 03:31 PM
Default I suck at driving
I went to Maple grove today and got two runs in, one was ok the other ruined my day .
1st run s16g at 22psi and launching abt 4k.
60ft 2.017
330 5.504
1/8 8.327
mph 86.85
1000 10.790
1/4 12.831
mph 109.96
Second run also at 22psi but launching at 5k
60ft 1.99
330 5.776
1/8 9.519
mph 57.81
1000 13.585
1/4 17.457
mph 56.85
Cluched slipped very bad in 1st and kept slipping in 2nd and 3rd so I just let the car coast. That pretty much just ended my day.
Old Nov 7, 2009 | 05:41 PM
you should be launching at least at 5k for any run on an AWD car. I would even think 5500. And then slip the clutch, well once you get a new one that is, haha. But you should be able to pull a mid to low 12's on that.
Old Nov 7, 2009 | 05:45 PM
I really wanted to end the season w/ a 12.5. Right now I'm searching to see whats a good setup to run. I'm thinking an act clutch/pp and fidanza flywheel.
Old Nov 7, 2009 | 07:17 PM
Yea your launch rpms are way to low. Without a 2step id look more in the 6-6.5k rpm range... get a good clutch first lol
Old Nov 7, 2009 | 07:40 PM
I have a 2 step but the 3 bolt rear will not hold up to that. Untill I get a decent clutch and a 4 bolt rear I'll use the 2 step.
Old Nov 8, 2009 | 02:49 AM
jason clipse's Avatar
ive got a centerforce dual friction and a fidanza 8lb flywheel that i havent put in.....should i be worried about this as well? i dont want to put in an aftermarket clutch then have to do it all over again.
and dsm, sorry to hear about that dude, though i get a lot of good info from u cause we are running basically the same setup
Old Nov 8, 2009 | 07:41 AM
Jason you should be fine w/ that set-up. I just really drive my car hard all the time lol.
Old Nov 8, 2009 | 07:52 AM
cool, i hate doing clutches, so i only want to have to do it once
Old Nov 8, 2009 | 08:06 AM
I was looking at the xtd stage 4 clutch kit and people on dsmtuners had nothing but good things to say so I might got one and try it out.
Old Nov 8, 2009 | 08:44 AM
xtd? never heard of them.....but let me know if it is worth it ie: u break a driveshaft cause of it
