'95 montero 3.5 dohc not starting
Old Nov 17, 2009 | 05:37 PM
wannakracka's Avatar
Default '95 montero 3.5 dohc not starting
I just got done replacing the valve stem seals, timing belt, water pump, etc... on my Montero. I put everything back together and it fired, but sounded pretty rough, so I cut the engine off. Since I have not been able to get it to fire. It turns over fine, but will not start. I have done some forum reading and plan on doing the following:
1) Check compression to make sure I didn't damage anything
2) Check for spark. Does anyone know how to do this with my particular Montero??? I do not want to damage the coil packs doing it the old fashioned way...
3) I have read It is common for a cam or cranshaft position sensor to cause problems. How can I check that these sensors are functioning properly? Note, I do not have a tool to read the MPI data.
Also, any other checks/ideas are appreciated!!!
Jmwatson14
Jan 13, 2016 06:14 PM
At1Maverick
Aug 14, 2014 09:59 PM
gpgtp00
Jul 1, 2014 11:35 PM
2yellowmonkeys
Sep 12, 2008 12:00 PM
Nubian QT
Oct 9, 2003 12:09 PM
