looking for solenoid valve for overdrive in 1990 montero.( please help )
Old Mar 22, 2010 | 06:02 PM
dewayne's Avatar
Default looking for solenoid valve for overdrive in 1990 montero.( please help )
would love to know where to find a A/T case solenoid valve for overdrive. Have contacted mitsubishi dealer, they said cant get that part, discontinued it. Checked with toyota dealer because its toyota trans. Checked all the local parts houses, no luck. Found 1989 mits montero in wrecking yard but the part wasent the same. Please some help from someone.
Old Mar 23, 2010 | 06:20 AM
Skiddy's Avatar
What is the transmission code? When you checked with the dealer, did they have a part number for the discontinued valve?
Old Mar 23, 2010 | 12:31 PM
dewayne's Avatar
the part number is MR111917 OR MD609445 old and new numbers for A/T case solenoid valve.
Old Mar 24, 2010 | 01:43 PM
Skiddy's Avatar
It appears Mitsubishi Parts have it in stock, might want to try there. Hope this helps.
Old Mar 25, 2010 | 08:59 PM
dewayne's Avatar
Default mitsu parts
says part not in stock maybe you have any more suggestions please thanks for your help
Old Mar 26, 2010 | 06:40 AM
Skiddy's Avatar
I'll check to see if there's an alternative part number, or another part you can use instead. In the mean time, there will be a tag in your engine compartment with a bunch of codes on it (usually on the firewall behind the air filter assembly). Can you post your transmission code? Thanks!
Old Mar 27, 2010 | 06:10 PM
dewayne's Avatar
Default thanks
i appreciate your help will get you the code as soon as i come in from work again thanks so much
Old Mar 28, 2010 | 07:54 AM
Skiddy's Avatar
No problem!
Old Apr 13, 2010 | 11:51 PM
dewayne's Avatar
Just got in from work, couldnt back sooner. I looked for any type of codes or numbers behind the filter box and all around. No luck on locating any tag of any kind. My wife says i cant find anything. I dO KNOW VIN# if that helps.
Old Apr 16, 2010 | 04:58 PM
Skiddy's Avatar
Can you PM me the VIN? Thanks!
