02 VR-X TCL Off lamp?
Old Apr 17, 2010 | 05:37 PM
Diamorte's Avatar
Default 02 VR-X TCL Off lamp?
Can anybody tell me the significance of the amber 'TCL Off' lamp that has started coming on intermittently? (And no, it is not the switch.) There is no obvious change in the behavior of the transmission. The light will just come on and stay lit for the remainder of that trip, then be off the next few times I drive it. Is it storing a trouble code?
Old Apr 21, 2010 | 11:31 AM
ryan51173's Avatar
Default Tcl lamp
Diamorte,
I have an 02 Diamante w/ 70,000. Same issue also. I believe you are looking at an ABS wheel sensor causing your TCL lamp to flash. It will ether be the contamination from the road, or it will actual be faulty. I've removed my passenger front and rear sensors on my vehicle. I've cleaned them and they now look brand new. That did not eliminate the TCL lite. I ran into having to drill and tap new holes for the bolt that holds the sensor. Maybe your bolts aren't as rusty. It wasn't a big deal. I'll move onto the driverside next and do the same. If cleaning the sensors doesn't fix the problem. Then I will have to meter out the sensors themselves for resistance and continuity to confirm they are good. I should probaly have done this while the wheels were off. I believe the connector that ties the sensor to the ABS control module are behind the plastic molded wheel well for the front and inside the trunk for the back. I do not have the spec for the ohm ranges handy and will have to look them up. I do believe the rear sensors are double in price compared to the front. They are two different sensors. I didn't do severe price shopping. I think the first couple places I looked the rear sensor was over $300.00. I hope they are cheaper than that. I'm am not in a big hurry to resolve this issue. It was only helping me in the snowy days in Buffalo, NY and it's alot warmer out now. On the other hand....I've lost my ABS. As of now, it's a work in progress. Does your ABS light also come on.? I also believe you can get an abs/brake diagnostic down on your car to verify what sensors is bad. I believ PEP Boys will do it for around $100.00.
GoodLuck!
Old May 18, 2014 | 04:10 PM
TheDonski's Avatar
what do you do when the tcl light is flashing and your car goes into a limp mode but it will shift threw the gears but you bulid speed slow as hell
Old Jun 10, 2014 | 11:36 AM
Kendsley's Avatar
Default Kendsley
I heard that you have to put a noise filter on to get it to go off?
I guess that would be a different type than you would use on stereo??
kk
mretheby
Jan 22, 2017 05:45 AM
ryan51173
May 18, 2014 04:13 PM
frankmanic
Sep 16, 2011 11:16 AM
06 eclipse
4th Generation
Feb 23, 2007 07:44 PM
dksnj
Nov 13, 2006 01:05 PM
