AC Evap Drain Location on 2003 Outlander pics
Old Jul 12, 2010 | 03:55 PM
Grudge302gt@att.net's Avatar
Default AC Evap Drain Location on 2003 Outlander pics
After scowering the internet for a week now to try to find any info i could on the location of the AC Drain i decided to go in and find it myself after coming up short handed. You will need to remove the air filter housing to get a good view of it as i found it impossible to get to from under the car. The power steering rack and k member where in the way. You need a 6mm ratchet to disconnect the 2 bolts that hold in the air filter housing and the bolt that tightens the house to the throttle body. At that point with a flash light the AC drain can be seen.
Old Jul 18, 2013 | 01:01 AM
paquinap's Avatar
thanks!
Old May 21, 2016 | 09:23 PM
Michaelmorgan1970's Avatar
Thanks. I had this problem once before and paid ac shop 100$ to clean it out because I couldn't find the drain. This picture and recommending moving the air filter housing was just the trick. I was able to shoot some air in and it starts draining right away. Total time from start to finish was 20 minutes. Thanks for this entry.
keith6110
Feb 26, 2014 02:08 PM
bdcorey723
Jul 16, 2007 05:23 PM
Bearwater
Aug 22, 2005 12:22 AM
hellsheep
Aug 7, 2005 06:34 PM
monkey714
Aug 3, 2004 11:31 PM
