error code P0506
Old Jul 15, 2010 | 06:09 PM
dalendianejanzen's Avatar
Default error code P0506
On my 05 Endeavor my service engine light came on and the meter says, P0506, low idle RPM. I have no low RPM issues or rough running at all. Any suggestions what is causing the light to come on?
Old Aug 1, 2010 | 02:52 AM
bbazookajoe's Avatar
This information is from mitsubi****echinfo website.
This code is tripped when there is a difference greater than 100rpm's between the engine speed and the "target" engine speed.
"TROUBLESHOOTING HINTS (The most likely causes for this code to be set are
*Throttle valve area is dirty.
* PCM failed."
It says clean the throttle valve area completely, erase the code and see if it resets. It says the next step is to replace the PCM. Personally i'd try replacing the throttle position sensor and motor before I did that.
This is assuming you've already replaced the air filter and checked the housing.
Old Jul 21, 2013 | 12:26 AM
catacami's Avatar
Exclamation How To Clean Throttle Body 2003, 2004, 2005 & 2006 Mitsubishi Outlander Engine Light
Watch my YouTube clip
catacami
Jul 21, 2013 12:30 AM
fastbg25
Feb 21, 2008 11:42 PM
anitarose122
Jun 28, 2007 11:08 PM
sp1viper
Apr 24, 2007 04:36 PM
Nubiebubie_GSX
Jun 7, 2006 02:16 PM
