amp wont power up
Old Mar 14, 2005 | 09:18 PM
1398spdr's Avatar
Default amp wont power up
for some reason my amp wont power up, everything is hooked up correctly and ive tried 3 diff. amps and 2 diff power wires, none of them power on, any ideas........... and its not the fuses..........
Old Mar 15, 2005 | 01:46 AM
m3kgt_99's Avatar
Default RE: amp wont power up
First of all, make sure your ground is in a secure place so that it is touching the bare metal of the frame somewhere. Second, check the fuse for your remote wire. If this does not work, you might want to replace the fuse that runs in-line from the battery to the amp. As I said, the remote wire might not be getting power either. Write back on any encounters you may have.
--Jed Booth LCpl. USMC
Old Mar 15, 2005 | 03:30 AM
DSMTalonAWD51's Avatar
double check your remote wire goin to your stereo. even if everything is getting power the amps not going to turn on without that correct. also, i dont kno if anyone with the eclipse infinity system has the same deal, but my amp only turns on if i power up the radio first and then go to the cd player. if i go to cd from off directly the amp stays powered off. i ran the same remote wire as the last owner did, so maybe she jus ran the wrong one or is that just how eclipses are??
Old Mar 15, 2005 | 05:12 AM
1398spdr's Avatar
yea, we thought about that too, but the remote wire is hooked up correctly also and i had subs in there before with the stock system, but now i put a new head unit in, the speakers still work fine with the stock amp, just the one for the sub wont power up......... the ground is good too.........[:@]
Old Mar 15, 2005 | 06:54 PM
vertstanggt's Avatar
Don't just visually check all those connections, get a multimeter and check for power at all those connections. Check the remote turn on when it should be on, check to see the power wire is giving power and just work until you find something wrong then go from there. If all this stuff is 100% there might be something wrong with the amp.
Old Mar 16, 2005 | 07:32 AM
1398spdr's Avatar
duh........... thanks, i hate electronics and always forget to use a multimeter.........
Old Mar 17, 2005 | 04:01 AM
No problem, you only remember stuff like that when you're forgotten to do it a whole bunch of times. Cause you never remember the simple things like that until after you've done far too much work and missed something really simple.
jram3324
Aug 17, 2010 10:54 PM
CarlisleP&SPaddy
Jan 26, 2010 10:32 AM
BrianWSNC
Oct 16, 2008 08:22 AM
RejectJC
Jul 24, 2007 11:25 AM
