Mitsubishi
Old 02-23-2007, 05:41 PM
bigolin bigolin is offline
Default RE: power antenna
KMC143
I have the exact same issue with mine. If I power on the stereo, the antenna raises, then the gears sound almost like they are grinding at the top. When I turn off the stereo, the antenna comes back down. Not sure if you did replace your antenna yet or not, but I've been thinking about doing it. Ifit worked for you, let me know. If you haven't done it, I'll let you know if it worked for me.Anyone have any good idea where I could find another antenna?
Old 02-26-2007, 09:39 PM
seaspearo seaspearo is offline
Where to buy 2001 Montero Limited power antenna mast?
I read the post, I know how to replace it, I opened the power antenna, seems the teeth of mast cable is worn out. I checked with dealer (in California, US), they want $65 for the replacement mast. I tried go online, but cannot find the any good deal. Couple of Ebay sell it for around $50. Anyone know where can I find the $12 deal?
Thanks!
Old 03-16-2009, 01:00 PM
wannakracka wannakracka is offline
I have a similar issue. My antenna will not raise when I turn on the car. When I turn the car off I can hear the motor trying to retract the antenna. The motor continues running until I turn the radio back on. Right now I have to disconnect the batt cable so that the antenna motor will not drain my battery. Is there a fuse I can pull??? has anyone had this issue?
Thanks for any help
Old 03-16-2009, 06:27 PM
tj90 tj90 is offline
I just replaced mine earlier this year. I paid ~45 dollars on ebay. It was a perfect fit. The job will require you to open up the splash guard under the wheel well and extract the broken antenna pieces inside the motor assembly. Not a hard job but definitely not a 30 min job either. Also, make sure you have some lithium grease on hand to lube the cable during installation and dont lose the metal pieces that thread into thebody at the base of the antenna.
Old 03-16-2009, 06:28 PM
Quote:
Thanks for any help
The motor should stop to prevent itself from burning out. It may take awhile but it should stop... Are you saying it will run longer than a minute?
Old 03-17-2009, 11:33 AM
Yes, it will run for longer than a minute. I have come out to my car several hours later and it was grinding away...
Thanks for our response.
Old 10-26-2009, 08:19 PM
tulsa44 tulsa44 is offline
Thanks for the info. I was trying to find info on this. I just bought a 2002 montero sport about a month ago. I believe that all I have is a broken mast, and that I got all of the old rubber "chain" out. I am having a hard time finding an afternarket replacement mast however. The dealer wants $70. I would think I could find it cheaper. Any national parts stores carry these?
Tags
antenna, fuse, mast, mitsubishi, montero, power, replacement, sport
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
