1G Eclipse/Talon/Lasor
Old Aug 12, 2005 | 06:17 PM
Thumpin79's Avatar
Default 1G Eclipse/Talon/Lasor
I was curious if anyone had a 1G and could help me with an electrical problem? My car wont start, the fuel pump works, the fuel filter is fine, but I have no spark and I cant figure it out. So if someone could help me out Id really appreciate it thanks
Old Aug 12, 2005 | 07:00 PM
Dyno_Man's Avatar
From: New York City...now residing in Fort Worth, Texas
Default RE: 1G Eclipse/Talon/Lasor
checked the spark plugs yet?
Old Aug 13, 2005 | 01:13 AM
DSMTalonAWD51's Avatar
does it crank? did you check the fuses?
Old Aug 15, 2005 | 05:48 PM
Dans Talon's Avatar
Check the computer code.
You may have a dead ECM.
Dt
Old Aug 17, 2005 | 07:12 PM
Thumpin79's Avatar
it cranks over just doesnt spark. And i have brand new plugs and wires. My buddys brother said that it sounds like the ECM.
Old Aug 18, 2005 | 01:45 AM
TheAntiCivic's Avatar
You try a coil?
Mines doin something similar, it cranks and I get spark but, won't start. Fuel filter, plugs, wires, coil, and module have all been done so far. ECU is my next option... If I do it before you're fixed I'll let you know.
Old Aug 18, 2005 | 10:12 AM
get435's Avatar
i beleve you car has a diatrubutor correct me if i wrong. here is what i would do start from the back and move forward with a test light first test the coil place the test light on the bare metal no the plug wire on the coil if it lights up bright it is alright than put the wire back on and take that wire off the dist and test it if it works than power is getting to the dist than do the same on the metal connectiods of the dis if they get power test all the wires.
Old Aug 18, 2005 | 09:33 PM
Thumpin79's Avatar
no it doesnt have a distibutor, it has an ignition coil and it ohmed out ok
blitzsuperstar
May 6, 2009 05:12 PM
paintballproam
Dec 3, 2006 12:32 PM
blitzsuperstar
Aug 21, 2004 07:37 PM
mopar4life
Aug 2, 2004 02:15 PM
