3000GT engine in a eclipse??
Old Aug 30, 2005 | 02:15 PM
terrymarron's Avatar
Default 3000GT engine in a eclipse??
I got a 2003 Eclipse GT. It has a V6 in it and i was wondering if i could take the engine out of a 3000GT since they are both the 6G72 engines. Im not sure if they would mount up the same or anything. Or if i could just take the internals and swap them into the eclipse engine?
Old Aug 30, 2005 | 02:40 PM
Patrick's Avatar
Administrator
Default RE: 3000GT engine in a eclipse??
im curious as to why you want to switch the motors??
Old Aug 30, 2005 | 07:04 PM
EcLites's Avatar
The problems you're run into when attempting this "swap":
1.)The intake manifold is completely different. It will not clear a stock hood clearance.
2.)Ttransmission is located on oppostie side. Eclipse's transmission is located on the driver's side, 3/S is on the passenger's. You might be able to pull it off, but you're gonna need custom motor/transmission mounts since the chassis is different.
3.)Hood clearance problem also applies to the valve cover, due to different head.
4.)3/S ECU will most unlikely be able to drive the stock gauges.
And if you were going to ask if we can do a 3/S DOHC head conversion, that won't work. Bolt pattern is different.
Just a little something i read elsewhere.
Old Aug 31, 2005 | 02:50 PM
Aight well i heard about people putting the 4g63 engines in a 2003 eclipse. How would that work and if it wouldnt what would be the best thing for me to do to squeeze some power out of that car.
Old Aug 31, 2005 | 02:56 PM
get435's Avatar
it is a v6 right headers intake exhaust and so on.
Old Aug 31, 2005 | 03:23 PM
Patrick's Avatar
Administrator
headers and a high flow car/test pipe evidently REALLY bring the 3g v6 alive...
Old Aug 31, 2005 | 05:02 PM
EcLites's Avatar
If you are going to be doing an engine swap use the EVO platform. Those are pretty much plug and play with the 3G's and it has been done before.
Old Aug 31, 2005 | 07:01 PM
Patrick's Avatar
Administrator
but going to a 4 cylinder will posess all of the mounting issues that putting in a 3000gt 6g72
Old Sep 1, 2005 | 04:05 PM
aight well i guess ill just stick with the v6 cause i found an a place where i can get a supercharger for the v6 and alot of other stuff for the engine. if anybodys interested go to rippmods.com well thanks for everybodys help anyways
Old Sep 1, 2005 | 04:06 PM
Patrick's Avatar
Administrator
yeah...good luck dealing with RippMods..
i tried for weeks to get in touch with them to order stuff...emails...phone messages left..and they never replied to me...i have also heard horror stories about people paying their RIDICULOUS prices, and having quality control issues....have fun
