93 eclipse GSX motor pull
Old Nov 20, 2005 | 04:26 AM
petro4411's Avatar
Default 93 eclipse GSX motor pull
can you guys tell me here what i have to take off this motor to pull it out of the car--does the tranny and transfer case have to come off?? can someone post a link that lays it all out for me???
Old Nov 20, 2005 | 09:56 AM
slow420a's Avatar
Default RE: 93 eclipse GSX motor pull
everything thats connected to the block.... tranny, sensors, fuel lines,vac hoses, ect.
Old Nov 20, 2005 | 10:16 AM
get435's Avatar
there are two ways to kae it out you can take all the motor mounts off and the drivetrain connections along with all the tranny connections to any other part of teh car and lift car up and there ya are or the simple hard way out the top and unbolt everthing including tranny not transfercase.
Old Nov 20, 2005 | 11:28 AM
petro4411's Avatar
thanks ----i'm going to try it out the bottom--seems to me the more stuff i can unbolt when the motor is out --the better ---the motor has a clanging noise from the low end--crank walk??? i read somewhere that the second half of ig cars were 7 bolt blocks is this true?? he put in a new clutch and 3rd gear before the low end noise--other than noise-car is loaded and mint--paid $700-is this a reasonable price for this car???----thanks for your help pete
Old Nov 21, 2005 | 10:34 AM
slow420a's Avatar
89-92 were the only 6 bolts, everything else is a 7 bolt. Use this as an excuse to drop a 6 bolt in.
Old Nov 24, 2005 | 03:01 PM
FireDoc's Avatar
Make sure that when you start unplugging things that you label each end of everything you disconnect. It makes getting it running much easier when you don't have to try to figure out where the other end of the plugs are.(some are in strange places)
Jacyn Grey
Jan 28, 2012 01:20 PM
ilovemy"Z"
May 4, 2009 04:51 PM
paintballproam
Jul 21, 2006 01:46 AM
EMonz57
May 4, 2006 01:14 PM
rogo_gst
May 18, 2005 08:38 PM
