2g 4g64 Head Swap
Old Apr 5, 2004 | 12:01 PM
SpyderGS's Avatar
Default 2g 4g64 Head Swap
I have the 7 bolt mitsu 4g64 from the 96-99 Eclipse Spyders and 91-98 Galants(i'm not totally sure, someone can correct me or verify). It comes standard SOHC, however, mitsu did produce a few DOHC 4g64's and they came in production U.S. Galant's in 1994(once again, verification needed). The DOHC 4g64 in the Galant makes 160hp standard, as compared to the 141hp in the SOHC Spyder. But most of that power comes from the higher compression pistons(10:1, i believe) and the cams. The DOHC does have the ability to rev higher than the SOHC,and that's the main reason i did my swap. In my swap, i used a 1g 4g63 non-turbo complete cylinder head and mated it tothe 4g64 block in my Spyder. The reason i chose the N/T(non-turbo) head was because the cams are designed for naturally aspirated use and since my Spyder isn't turbocharged, there was no sense in using the head from a Turbo 4g63. To swap heads, you'd need a 1)complete cylinder head, cams on down 2)Timing belt from a DOHC 4g64(the above mentioned galant is the only US car using it) 3) intake manifold and supporting acessories(Throttlebody, tb elbow, etc.), And a list of otherpieces. There is a complete list of parts needed on the Yahoo's Group 4g64forum and also onhttp://wraithnet.net/4g64/. Many thanks go out to these guys, they really are the pioneers of this engine. I was fotunate enough to have my friends 93 NT eclipse break down and got parts for free off it<IMG src=smileys/smiley17.gif border="0">. There are a few whole on the block that need to be plugged, not really a problem, but they NEED to be plugged. I will be writing up my swap procedure in another post soon, and attach it as a sticky. </P>
Old Apr 5, 2004 | 12:39 PM
monkey mitsu's Avatar
Awesome. you should destroke it a bit and rev Super High.. thats the first N/A Head swap Ive heard of. Did it bump compression at all with eclipse Head? on the 6Bolt Hyundai version they said it did to theirs because there was alot more dish in the hyundai head than the 1G head. </P>
Old Apr 5, 2004 | 01:34 PM
SpyderGS's Avatar
As far as i can tell, Compression is basically the same. I am using an Evo Metal head gasket though, so i'm not for sure. I was thinking of going thinner to bump compression up to maybe 9.5:1 or even 10.0:1, but since i will be going turbo(hopefully soon), i'm just preparing. Yeah, i'm not sure why many people don't do the NA head swap, the heads are basically the same except for the cams. At first i didn't want the NAhead because i was planning to go turbo soon afterwards....but that stuff takes money. Plus my friend killed his 1g NT. So free parts have a way of changing my mind. Anyways, i can gaurantee i'm not putting out more than 160hp. Perhaps, 155hp if i'm lucky(i'm talking crank by the way), and most of that is from the intake and exhaust mods. This swap probably only gave me 5-7hp total. That's along with the 60mm tb. Not much in gains, but i can now rev hard and fast<IMG src=smileys/smiley2.gif border="0">. Power comes quicker and i can run through the gears a little quicker now. Top end isn't that great, but it's better than it was with the SOHC. I also did the 2g ecu swap for the rev limit change. I'm using an Apexi SAFC to get it all leaned out, but it's still a little rich on the bottom end. I want a Greddy emanage to get it all going right, but i'm still poor. Anybody wanna donate some money? Or maybe a turbo? Anything?
Old Apr 8, 2004 | 10:50 PM
Spyderman9803's Avatar
The turbo head would have worked just as good as the non-turbo one, just a little more aggressive cams in it pretty much. When are you planning on going turbo? I just did the conversions for DOHC and boosting the motor. What are you planning on using to tune your car? I'm still trying to decide what I want to use so I can get it and finally tune mine and get it running within good parameters. Where is everybody located anyways? I'm in SC.<IMG src=smileys/smiley1.gif border="0">
Old Apr 8, 2004 | 11:20 PM
Im in Louisville KY movin to Indianapolis. What turbos are you guys planning on using?
Old Apr 8, 2004 | 11:29 PM
I'm running a 14b until I can afford somethinga little more hefty down the road. I had to have mine rebuilt when I purchased it because I got it out of a junkyard car.
Old Apr 16, 2004 | 03:28 PM
ForceFed4's Avatar
If you guy's are interested I can port match your turbo housings and ceramic coat themto promote less heat soak into your air intake track. I have seen asignificantdrop in engine compartment temps on my ownveh wich helped drop intake temps. Also when I ported my exhaust manifold and turbo housingiteliminated lagtremendously.</P>
Thanks Mike!</P>
1(248)249-5983 cell</P>
Old Apr 17, 2004 | 03:53 AM
how much do you charge for coatings?
Old Apr 19, 2004 | 08:05 PM
ForceFed4's Avatar
Let me know what you need coated it's based on material I have to use, and that depends on the part size. It's not very expensive compared to the gain you will receive. here are some average prices for general heat reflective coatings.</P>
1) Combustion chambers and valve faces ( ceramic ) $ 32.00 ea.</P>
2) Piston tops and skirts ( sides-moly bendum / tops- gold ceramic ) $35.00 ea.</P>
3) Crank shafts 4 cyl eng. ( oil sheding reduces windage ) $ 125.00 ea.</P>
Give me a call or e-mail me and we can work out some deals mjsanders22@hotmail.com or 1-248-249-5983 cell</P>
Thanks! Mike</P>
Old Apr 20, 2004 | 12:43 PM
SpyderGS's Avatar
Sorry for the late reply, but Forcefed i have a question. Will the Piston Top Coating(Gold Ceramic) make the top of the piston more resistant to detonation? I'm gonna overhaul my engine pretty soon, and the prices of forged 4g64 slugs are still sky high. So i was trying to find if there was a coating that would help the stock pistons through the rigors of forced induction.I also have a new 7cm turbine housing that will be matched to a small 16g. It doesn't need porting, but the coatings seem interesting. </P>
For spyderman, i got a pocketlogger for tuning. It's absolutely great, it can monitor everything you can imagine and logs data. Usually, i tune in second or third gear using my SAFC, depending on where i'm driving. First i set the SAFC to the best combination i think. Then i make a few runs and see how things are on the pocketlogger. If the EGT's area outta range,i'll lean things out or richen them up. I try and keep everything within the best range possibe, i'm not turbo yet so i don't really need to worry about a lot of things. I'll be going turbo probably this summer. I still have a few odds and ends to tie up. My biggest obstacle is i have a first gen exhaust manifold. I need either a 2g or evo manifold....but i spent my money on the 7cm turbine housing. Plu, i need tires right now, mine are bald....really bald. </P>
