Wow, Suspension is Big $$$
Old Mar 17, 2006 | 06:37 AM
WIECLIPSEGUY's Avatar
Default Wow, Suspension is Big $$$
I had to start replacing Front Suspension parts, Hub Bearings, tierods and Ball Joints/control arm.... And Dang, things are Not cheap to have done. I still have bearing noise in the rear of the car as I go down the road. Are there Hug type bearings in the rear of the car with it being AWD? Just wanted to know what to expect.[8D]
Old Mar 17, 2006 | 05:21 PM
Sanguinius's Avatar
Default RE: Wow, Suspension is Big $$$
Might get a bit better response in the Eclipse section on this. I think there was a thread about noise after susp work in there a while back. I don't remember if they had AWD or not but give it a check.
Old Mar 18, 2006 | 12:17 PM
Thanks Sanguinius....
Old Mar 19, 2006 | 04:35 AM
Sanguinius's Avatar
No problem. That's what we're here for. Good luck.
Gstfat
Apr 30, 2008 10:32 PM
SCmitsuchic
Feb 22, 2008 01:26 PM
burnmyeyes
Dec 14, 2006 12:08 AM
Spyderman9803
Feb 26, 2006 10:59 PM
Ray00
Jan 20, 2004 03:30 PM
