Mitsubishi motor codes
Old Mar 29, 2006 | 11:49 PM
slow420a's Avatar
Default Mitsubishi motor codes
Alright if you find anything out of place or a mistake let me know, I got alot of this info from a online source(non mitsubishi) so I wouldnt be suprised if there were some mistakes.
Many have asked what motor does my car have, or what motor is this. Here is a directory that will explain them all, before I go nuts here is a bit of info that will help you read the motor codes.
Mitsubishi uses a mix of numbers and letters to name their motors
The first digit is the number of cylinders, the second is the fuel type, the third is the engine family, and the last is the model. So a 4g63 is a 4 cylinder, gas, number 6 family, model 3 motor. Note that some cases the first number was dropped to add room for a 5th number either a "t" for turbocharged or "b" for second generation... like a 6 bolt or 7 bolt motor.
EFI= electronic fuel injection
SOHC= single over head cam
DOHC= double over head cam
For the Inline 4 cylinder motors the family/groups are as follows
4g1x- 1.2 to 1.5 liter motors
4g3x- 1.2 to 1.8 liter motors
4g5x- 2.0 to 2.6 liter motors
4g6x- 1.6 to 2.4 liter motors
4g9x- 1.6 to 2.0 liter motors
For the v 6 motors
6a1x- 1.6 to 2.5 liter motors
6g7x- 2.5 to 3.8 liter motors
4G1X motors: 1970’s old school motors, introduced with the colt and colt related cars. All are iron head/block motors only EFI motor is the 4g15.
4g11- 1.2 liter sohc
4g12- 1.4 liter sohc
4g13- 1.3 liter sohc
4g15- 1.5 liter sohc w/ gas direct injection
4g16- 1.2 liter sohc
4G3X motors: 1980’s motors, all motors aluminum head/iron block. Motors used in mitsu cars along with hyundia cars.
4g32- 1.6 liter motor sohc
4g33- 1.4 liter motor sohc
4g66- 1.2 liter motor sohc
4g37- 1.8 liter motor sohc
4G5x motors: All sohc motors, these were the first motors to use a balancing shaft earning them the title of silent shaft motors. Also these cars used a extra intake valve(similar to vetch). These were used in many Mitsu’s along with Mazda’s and Hyundai’s. Cast Iron blocks/aluminum heads some had EFI.
4g52- 2.0 liter motor sohc
4g54- 2.6 liter motor sohc
4g55- 2.3 liter motor sohc
4G6X motors: found in many mitsu/dodge/hyundia/plymouth/eagle cars. Came in many different models, sohc, dohc, turbocharged, 6 bolts 7 bolts. All motors cast iron block/ aluminum head, most EFI motors.
4g61:- 1.6 liter motor dohc
4g62:- 1.8 liter motor sohc
4g63:- 2.0 liter motor sohc/dohc
g63t:- 2.0 liter motor sohc/dohc
4g64- 2.4 liter motor sohc/dohc
4g67- 1.8 liter motor sohc
4G9X motors: These are the newest motors Mitsubishi has made. These motors are sohc, dohc, or mivec. All cast iron block/aluminum head, EFI.
4g92- 1.6 liter motor sohc/mivec
4g93- 1.8 liter motor sohc/dohc
4g94- 2.0 liter motor sohc
6A1X motors: v6 motors produced by mitsu, the 1.6 is the worlds smallest 6 cylinder motor mass produced. All cast iron block/aluminum head, EFI.
6a10- 1.6 liter motor dohc, the worlds smallest mass produced v6, apparently it was the most sought after motor for tuners in Japan, it was recorded at making 430bhp n/a.
6a12- 2.0 liter motor sohc/mivec… not so famous
6a13- 2.5 liter motor, still in development
6G7X motors: available with sohc, dohc, or mivec. All motors have a cast iron block/aluminum head. All EFI.
6g72- 3.0 liter motor sohc/dohc
6g73- 2.5 liter motor sohc/dohc
6g74- 3.5 liter motor sohc/dohc/mivec
6g74 GDI- 3.5 liter motor, first GDI motor of its kind.
6g75- 3.8 liter motor sohc/dohc/mivec
Lastly the mistu/mopar motors. Unfortunately not a whole lot of info exists on these motors because they are not seen as performance motors, also currently manufacturing of the neon/eclipse Chrysler motors has stopped meaning they are soon to be a thing of the past.
A1.8- 1.8 liter sohc motor
A588- 2.0 liter sohc motor most commonly found in neon’s
420A- 2.0 liter dohc motor, 2g non turbo eclipse motor
EDZ- 2.5 liter dohc motor, swap for the 2g non turbo eclipse
EY7- 2.5 liter sohc motor, swap for the 2g non turbo eclipse
EVD- 2.5 liter dohc turbo motor, used in the pt curser r/t
EDT- 2.5 liter sohc turbo motor, used in the srt-4.
Like I said if I missed something pm me with the corrections. Also a car/motor cross reference list is in the works.
Old Jul 17, 2007 | 11:00 AM
cd's Avatar
cd
Default RE: Mitsubishi motor codes
im new here and looked at you lol can you tell me i bought a 1995 3000gt non turbo and the motor has blown after having it only 4 days can you tell me what motor will fit in there. i just need to get it running for now not ready to put alot of money into it at this time.
Old Jul 17, 2007 | 04:12 PM
Dusty Eclipse's Avatar
Theyre the 'Stellar' engine models made by Mitsu. Each set had a nickname... This is useless info... but since I know it, now you have to also... ha ha ha!
4g1x - Orion
4g3x - Saturn
4g4x - Neptune
4g(d)5x - Astron (The Diesel vareity also had this name)
4G6x - Sirius
Old Apr 16, 2008 | 09:12 AM
ace147's Avatar
i mave a 98 mirage could you tell me what code fits with my engine?
Old Jul 17, 2009 | 09:32 AM
9Colt's Avatar
I have a '94 Dodge Colt with the "Orion" engine 4G15. What is the largest replacement engine and tranny I can bolt into this car using the same mounts etc.
Old Dec 3, 2009 | 04:12 AM
preetyp's Avatar
Thanks for codes.Good information. the 6G72 twin turbo engine is responsible for pushing the heavy 3000GT/GTO to 100 km/h in around five seconds.
Old Jan 28, 2010 | 12:31 AM
juriskardowski's Avatar
thanks for the codes. Anyway i'll be asking for an additional help, i have this fifth generation mitsubishi mirage, i will appreciate your help dude if you can tell me the code which fits to my engine.
Old Dec 31, 2010 | 01:22 AM
joe#3's Avatar
Default help i need lowering springs
I have a 2006 Mits. Galant GTS i just put rims on and would like to lower it i need help to find some lowering springs 2"to 3" please thanks
Old Jun 8, 2011 | 07:27 AM
rutherfordred's Avatar
For the v 6 motors
I am new to this forum, i found your post is very informative i really want to thank you.
Old Dec 22, 2011 | 03:26 PM
ed1234's Avatar
DO YOU HAVE ANSWER FOR THIS ?
Hi I have a mitsUBISHI L200 1986 with 4 headlights. The inside pairs are staying on when i put it on dip CAN YOU GIVE ME ANY HINTS ANY INFO THANK YOU
Make: Mitsubishi
Model: L200
Year: 1986
Engine: 4G63B
Already Tried:
I have taken the stalks etc off steering wheel to look at mechanism appears to be working ok, Managed to get the flasher on lights to work, hasn't for a while. I think it is the relay thing because it appears to not switch them off, but I can't get a new one to try
ALSO DO YOU KNOW HOW TO GER RADIO CODES FROM WHERE AND HOW
