need a fast answer please
Old Apr 19, 2006 | 12:48 AM
95HGeclipse's Avatar
Default need a fast answer please
im building a 420a engine and its gotta be done by mid june does anybody know if neon JEpistons would work for the eclipse since there both 420a engines and i would buy the pistons ment for the eclipse except there all 20 over bore and im trying to keep the engine at the stock bore
Old Apr 19, 2006 | 09:56 AM
n2daizo123's Avatar
Default RE: need a fast answer please
Wiseco sells pistons at standard bore at 8.8 and 10.5 compression and they are a little cheeper than je pistons.
Old Apr 19, 2006 | 11:42 PM
think they would hold up as good as je pistons and later on the engines gonna get a turbo do alot of people use them with boosted cars
Old Apr 19, 2006 | 11:56 PM
n2daizo123's Avatar
I ordered a set for my car a couple of days ago and i will be running about 1.5-1.6 bar on the motor.
I got this off ofslowboyracing.com:
Wiseco has been making quality piston designs since the 1960's. Extending into the Automotive Market after several succesful years in off road sports, they quickly became known as one of the very best Sport Compact Piston Manufactures in the world!
I got this from wisecos web site:
Wiseco is dedicated to staying abreast of technology in the PowerSport industry. Wiseco engineers utilize the latest in 3D design and finite element modeling software to ensure every Wiseco design is developed to provide the greatest strength and lightest weight for each application. Our in-house Dyno facility, equipped with the latest technology, along with our field-testing network, insure that our products meet the expectations of the demanding PowerSports industry.
Wiseco is focused on continually refining our quality culture and our associates are dedicated to living up to our Quality Policy: “To Meet or Exceed Customer Requirements Every Time.â€
Quality, integrity and service are the backbone of Wiseco’s success. No other piston manufacturer can match Wiseco’s advanced technology and care for detail. That’s why the top engine builders and racers in every PowerSports industry have come to appreciate and depend on Wiseco for consistent winning results.
Old Apr 21, 2006 | 12:57 AM
do you know if they will fit on to stock size eagle rods? cause i got them for the engine
Old Apr 21, 2006 | 03:54 PM
n2daizo123's Avatar
They should because i also ordered eagle rods for mine.
Old Apr 23, 2006 | 09:52 PM
well im set
Old Apr 24, 2006 | 11:05 AM
n2daizo123's Avatar
Have you looked at the cylinder walls? you might want to take the block to a machine shop to see if it just needs to be honed or if it needs to be bored over before you buy the pistons.
Old Apr 24, 2006 | 12:45 PM
slow420a's Avatar
Any time that you rebuild a motor the wall should be honed, even if you do it your self with a ball hone(very crude way of doing it).
XxM4n1aCxX
Oct 11, 2008 11:06 AM
stoksux
Aug 20, 2008 01:55 AM
eclipseonjuice
Feb 13, 2006 02:36 AM
westtexas
Jan 31, 2006 01:15 PM
green_eclipse94
1st Generation
Nov 18, 2005 10:31 PM
