2004 Lancer Coil not firing
What makes the coil pack fire is it crank senor or the cam senor?
both where replaced and car did would not start. I pulled engine code and it says that the new camshaft senor is bad. I replaced with the old cam sensor. The car now starts but it is only running on two cylinders. The coil pack is new, and as the car runs it gets very hot. I have an ignition tester and the other coil is firing.
