03 montero sport rear coil removal-need help
Old 01-22-2017, 10:14 AM
Troyhall's Avatar
Default 03 montero sport rear coil removal-need help
Hi. I am needing to replace my rear coils on my 03 montero but can't figure out how they come out. Any help is appreciated.
Old 01-25-2017, 08:51 AM
Tdub1966's Avatar
Default coil removal
to remove coils remove bottom shock bolts, remove passg side sway bar bolt (or connection bar?), sway bar bolts both sides then Jack the vehicle from tow hitch if you have one, be careful you watch the brake line and vent hose at top drvr side of axle housing that you don't break them, u can generally pull them out without problem but re installing I find it easier to use spring compressors and to remove drvr side rear wheel for that side makes it a lot easier.
Old 02-22-2018, 02:21 PM
hichamaziz's Avatar
if you don't know it must be done with an expert
davidsdlck
12-22-2020 06:51 PM
mitsuba
03-23-2019 08:38 AM
mlahrens
01-29-2016 06:54 AM
markydeva
09-15-2014 04:26 PM
jimdurt
15
12-28-2011 08:55 AM
Quick Reply: 03 montero sport rear coil removal-need help
