Can i do it myself?
Can i do it myself?
Hi i was wondering, if i got lowering springs for my 98 eclipse spyder, if it is easy enough for a not so experienced mechanic to install? Is there any modification that has to b done? or is it just swapping oem for aftermarket?
there is no modification however i would highly suggest you get better struts as well because lowering the car will put more wear on the stock struts and will eventually blow them out. So your better off doing it now. As far as the install its not too difficult. Im sure you could find a how to online somewhere. As long as you have a basic tool set you should be fine. Only thing you will need to do is go to autozone and rent a spring compression tool.
