wheel hub bearing bolt torque specs
Old 10-05-2011, 02:21 AM
Ronald b's Avatar
Default wheel hub bearing bolt torque specs
I have a 2005 endeavor and a 2005 galant 4cyl. I wish to replace the wheel bearings. I already have found out that the torque spec for spindle nut is 167 ft/lbs on both vehicles. What I need is the torque specs for the 4 bearing bolts, for front and rear bearings both cars. This is my first post and I am new to this so I apologise if the format is incorrect. If someone has this information I would be most grateful.
Thank you, Ronald b
TheEngineer
01-26-2016 03:32 PM
cbowman7
08-29-2011 05:28 PM
steve--
08-14-2009 07:56 PM
agallardo
02-22-2007 01:57 PM
agallardo
01-29-2007 01:10 AM
Quick Reply: wheel hub bearing bolt torque specs
