1990 gs
Old Mar 11, 2008 | 08:19 AM
  #31
dsm1990gsx's Avatar
Default RE: 1990 gs
ORIGINAL: xtanmanx
not to sound like an ***, but not sure what you are talking about looking at dates. i found a thread that has to do with the same thing i am dealing with and posted to it, bringing it back to top. as for the fact that you answered in the other thread, if you look at the time, you were answering the same time i was writing in this thread.
moot point anyway..geting rid of car.
You brought upa thread from november, if you have a question keep it in your other thread to make it easier for others to helpfix your problem.
Old Mar 12, 2008 | 02:57 PM
  #32
xtanmanx's Avatar
Default RE: 1990 gs
ORIGINAL: dsm1990gsx
Check your coolant temp sensor, if its bad it'll tell the pcm to add more fuel-rich..
is the coolant temp sensor the same one that senses temp for fan? i thought these are normally 2 different sensors. my fan wont come on when its hot enough that it should. and since it tells the ecu engine temp, would this cause the ecu to have the wrong mixture setting? my car was blowing black smoke when i would get on it before it overheated, and ONLY when i would romp the pedal.
2nd post in the thread has EVERYTHING to do with my quesiton
Old Mar 13, 2008 | 07:48 AM
  #33
dsm1990gsx's Avatar
Default RE: 1990 gs
ORIGINAL: xtanmanx
Well its obvious you don't understand what I am saying,so sinceyou act like you know everything I guess you can figure outyour own problems.
magicman909
Jun 22, 2004 05:21 AM
magicman909
Apr 27, 2004 06:02 PM
3sMike3s(PA)
Apr 24, 2004 05:38 PM
magicman909
Apr 22, 2004 01:56 AM
horine
Apr 13, 2004 02:49 PM
