1990 gsx problem
ok the problem is i have no power to the fuel pump and it seems there is an open ground on the injector... which is probably the same problem... any ideas?
Pull out the ecu and inspect the caps.
I have an extra ecu... with no luck... swapping it will not fire... can it be a bad knock sensor?
