92 GS idles over 2000rpm
My 92 GS auto idles at over 2000 rpm, is the idle adjustment/ISC test the same for the auto as it is for the manual?
RE: 92 GS idles over 2000rpm
It should be the same test. If you're not sure get a Chilton's or Haynes service manual and double check.
The 2.0 egines use the same iac and all the tests are the same.
