93 eclipse gs front wheel bearings
Can anyone give me the specs or size or bearing number for the front wheel bearings for a 93 eclipse gs 2.0 dohc non turbo?
Some numbers would help, timkin, skf....whatever just so I can go to a bearing house. Thanks |
RE: 93 eclipse gs front wheel bearings
best i could find
http://catalog.masterautoparts.com/i...asterautoparts |
Need more info with all the gear heads on this site there has to be someone with some onfo on a replacement bearing number to obtain a bearing from a bearing house.
best bet call the dealer they can tell ya.
i couldnt even find that and replacing a wheel bearing is kinda a pain in the nuts they have to be pressed out and pressed in (not hammered out and hammered in) so your best bet would be if you dont have your own shop with a press and good power tools... just take it to your local shop and have them do it..
P.S. buy a manual for your car.. those things have eveything you need to know about changing and fixing things on your car :-) Repair Manual For 93 Mitsu Eclipse GS |
