Datalogging
Old Dec 5, 2005 | 04:13 PM
92_laser's Avatar
Default Datalogging
I have a palmIIIxe with mmcd and I cant figure out how to get everything to log. It will log RPM, knock, and not much else. How do I get it to log fuel mixtures and engine temp ect... I also downloaded Palm"n"stein to try that but I cant get it to sync to my palm... Any help would be greatly appreciated. Thanks
Old Dec 6, 2005 | 12:04 PM
DSMTalonAWD51's Avatar
Default RE: Datalogging
there are forums dedicated to logging and palm logging, id try there as your problem seems to be uncommon here. I am using a palm logge but havnt ever had any problems so I wouldnt kno what to tell you.
Old Dec 8, 2005 | 12:36 AM
rganders315's Avatar
Do you know if there are options for other cars for that type of logging. That is pretty slick.
Old Dec 8, 2005 | 05:14 AM
there are general odbII pocketloggers that are sold at pocketlogger.com and on ebay for around $100-150, but what it logs is dependent on what parameters your ecu can send out through the data port, all cars are different. dsms are display a lot such as rpm, coolant temp, short term/long term fuel trims, timing etc. 1g's are lucky because they get to see knock, the 2g's dont
