distributor
Does anyone know how to change the distributor on a 92 Talon 2.0 NT? Any help would be great. Thanks
RE: distributor
What do you need to know? The distributor is held in by a single nut. Remove the nut, distributor pops right out. Are there specific issues you need info on?
RE: distributor
The distributor is under the intake manifold, right? If so, then do you have to take the intake manifold out? or how do you get to it?
RE: distributor
well, i dont know much about the 2.0, but i looked at a pic of the engine bay and my guess would be yes, it is under the intake manifold. If it is, unless you are extremely flexible and skinny and coordinated, then yes you more than likely need to remove the intake manifold. then there is just one bolt holding on the distributor
RE: distributor
ok, Thanks
