-   1st Generation (https://mitsubishiforum.com/forum/1st-generation-62/)
-   -   ECU (https://mitsubishiforum.com/forum/1st-generation-62/ecu-20919/)
SILVER Aug 12, 2007 11:43 AM
RE: ECU
mmmmmmmmm, thats weard!
superhumankiddy Aug 12, 2007 03:49 PM
RE: ECU
yeah, I know, tell me about it. This car is a whole lot of trouble, but I love it, so it's worth it.
1987 TSI Aug 18, 2007 10:02 AM
RE: ECU
you probably not the same problem ECU you had. From what I have found out the capacitors are notorous for going bad in those ECU. As a matter a fact I have been having the same problem. Either the ECU should have the capacitor changed in it or a remanufactured ECU will have modern parts in it.
Now, I have a Question, I replaced my ECU and now the car runs but I still have no fire to cylinders 2 and 3. (which is probably what you are experiencing when you say "like the mass in unplugged.) I have new coil packs on as well. Crank/cam sensor is functioning. ignition module maybe? Any ideas?
sorry to highjack
superhumankiddy Aug 18, 2007 12:28 PM
RE: ECU
I unplugged the MAS and the running changed a lot, so I take back it acting like the MAS is unplugged. When at idle it idles like it normaly does, but when I'm driving and I'm going slow with the RPMs at around 3 to 4000, it kinda slightly jurks back and forth, well not jurk. It's hard to explain. I do plain on having my ECUrebuilt, so I'll see what that does. Thanks
brycesworld Oct 27, 2008 11:43 PM
RE: ECU
Mine is doing the same thing? What did you do to fix it?
Thanks
Bryce
dsm1990gsx Oct 28, 2008 12:30 PM
RE: ECU
ORIGINAL: brycesworld
Thanks
Bryce
Check the dates before you post.
brycesworld Oct 28, 2008 08:13 PM
RE: ECU
ORIGINAL: dsm1990gsx
Thanks
Bryce
I did, however being that I am having the same exact issue and couldn't find it anywhere else in the forum I decided to ask the person who might be able to help me since they were in the same boat.
Maybe you should try leaving useful advice when you post. Or at least answering the question that was asked instead of butting into a conversation that does not concern you. Thanks.
dsm1990gsx Oct 28, 2008 08:16 PM
RE: ECU
Thanks
Bryce
Or you could start a new topic w/ your concern and it makes it easier for people here to solve your problem. I wasnt trying to bea dick just trying to help a newb.
