evo swap
hey guys im new to this site and im pretty new to the eclipse/talon cars. anyways i have aquired a crashed 2003 evo body is beyond repair but engine and drivetrain are good. I want to see if i can swap any of the evo into my 1992 eagle talon tsi awd
RE: evo swap
Not without heavy modification. The engine is setup backwards from your 4g63 and the transmission also goes on the opposite side.
RE: evo swap
Nope you cant use the eng/trans since everything is oposite form the 1g 4g63 engine/trans. You can use small stuff like the fuel pump and injectors. Try searching to see what parts areusable in a 1gen.
RE: evo swap
Just part out the evo. You will get some good money doing that
RE: evo swap
ya you could probably get quite a bit if you parted it out on like dsm source and a few websites. te the evo injectors are better than the stock gst ones arent they? could i directly swap them in to my gst? and the fuel pump is better too correct?
RE: evo swap
you can swap the injectors. I believe they are like 550's or something. But i wouldnt bother with the EVO pump. That is actually a weak link in that car. Better off getting a walbro
RE: evo swap
ORIGINAL: TheEngineer you can swap the injectors. I believe they are like 550's or something. But i wouldnt bother with the EVO pump. That is actually a weak link in that car. Better off getting a walbro |
