fires on @ 1
1.8 gs none turbo it will onley fire on # 1 and i have no power to the fuel pump anybody no wy its doing this thangks for any help greg
RE: fires on @ 1
Are you getting an injector pulse?
RE: fires on @ 1
yes all the time i was getingpuls to all of them but no fule past the injeckters. sinc i ran the wirefrom the realay.im geting fuel but no sparck ecept on# 1 and all the plugs are wet.evan #one whith a blue spark.and it is fireing on # top dead center in the cap.do you thingk if i set the disttributor one gear aheadit should or would fire. the book says to line it up in the cap on#one i trid both ways but got puls on the injeckters but no fuel. if you dont mind i could call you at your covinyanc to try to figeyer this out.thangks greg.
RE: fires on @ 1
ORIGINAL: gregfirestone yes all the time i was getingpuls to all of them but no fule past the injeckters. sinc i ran the wirefrom the realay.im geting fuel but no sparck ecept on# 1 and all the plugs are wet.evan #one whith a blue spark.and it is fireing on # top dead center in the cap.do you thingk if i set the disttributor one gear aheadit should or would fire. the book says to line it up in the cap on#one i trid both ways but got puls on the injeckters but no fuel. if you dont mind i could call you at your covinyanc to try to figeyer this out.thangks greg. |
RE: fires on @ 1
RE: fires on @ 1
